Old 09-16-2010, 09:10 PM
Default Lights for an original
Last weekend, I grabbed a spare light switch for a NF and looked at my original lights that have been lying around for the past year as I debated to drill holes in my grill frame of my restored original, then I decided it was time to take a more serious look at installing them. After all, I could always find an original grill frame if I wanted to put it back. So, I went looking for a hole to install my light switch in on the left side, like the NF's, but did not see any. Can anyone tell me where the light switch for an original should be installed or where the IH recommended it be installed? Thanks in advance!!
Old 09-16-2010, 09:38 PM
Sminkey
Guest
Posts: n/a
http://ccmanuals.info/pdf/O%20Light%20Install.pdf
That should help ya out!!
Old 09-16-2010, 11:17 PM
Thanks Sminkey......As I kind of suspected, I have to drill a hole, which I'd rather not do. Think I might give this one some more thought and maybe engineer a bracket that could make use of some pre-existing screws/bolts!!!
Old 09-17-2010, 04:59 AM
nikster's Avatar
nikster nikster is offline
I am determined to add lights to my projects. I've been tinkering in thought about how to do this?
I really don't want to drill any holes or buy the adapters & lights that I see on E Bay, way to much $$ that I don't wanna sink in.
But I gotta have lights. I just thought of how many times I've plowed with my rinky-dink crapsman & to keep ahead of the snow it seems I always plow at night at least once or early morning.
I have some fog lights from a car that were NEVER mounted. They would mount perfectly as described in 'Sminkey's post' which i will use & improvise as I see fit.
Thanks for the post & info,
Nik
Old 09-17-2010, 10:50 AM
I have 2 grill housings that has holes drilled into it already,I only need one of them for my original so I can add lights.Gotta have lights.
