Old 06-02-2024, 10:56 PM
johnhenry johnhenry is offline
Default Cub 782 Kt17 Series II Fuel Starvation when Hot??
I have a nice Cub 782 Series II that starts and runs fine mowing for about 15-20 minutes and then suddenly seems to die unless heavy choke....fuel starvation?? I replaced the fuel line between pump and carb, It seems to have plenty of fuel in the see thru filter just before the pump. Gas will gush out of the pump with the line disconnected after the pump (when cold, seemed unsafe to try when hot). Anyone have experience with heat sensitive fuel pumps or other ideas???
Old 06-03-2024, 05:30 AM
It could be your fuel cap is not vented and causes the starvation. Loosen the cap and see if that solves your problem.
You could also have an ignition coil problem. I'm not sure what engine you have but if the above fix doesn't solve your issue that's where I'd look next.
Old 06-03-2024, 08:12 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I would ensure the points and condenser are quality OEM units adjusted to spec. Then I would look at the coil. Sounds like a heat related failure. The fuel cap is an easy check.
