Old 05-31-2023, 10:56 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default IH CC 70 mower deck belt questions
Hi everyone. Just the other day I got my International Cub Cadet 70 to start for the first time in 20 years. However, the mower deck/mule drive belt snapped off before I even tried to engage the mower deck. I have some questions, some of them might be kind of simple but I’m not exactly understanding the set up on this old mower.
Are the mower deck belt and mule drive belt the same thing?
How do the 2 pulleys towards the front of the machine work?
Will this belt on eBay work for me? I have the 38 inch cut…
https://www.ebay.com/itm/30149522174...Bk9SR-6ZzsqOYg
Thanks for any help!
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 06-01-2023, 07:23 AM
On your typical Cub Cadet tractor with a Mower Deck attached, you will have two belts:
* Mower Deck Spindle Belt
* Mule or Drive Belt.
Belt sizes are determined by the Tractor Model and Mower Deck model combination. IE: CC 70 w/38" Deck.
Attached is a typical Mule Drive Belt application.
The correct belts for a Cub Cadet 70 with a 38" Mower deck:
* IH-473462-R4 Mule Drive Belt
* IH-473468-R2 Spindle Belt
This is assuming this is a OEM stock application and no modifications were made.
NOTE: Belts generally break when there is a "mis-alignment" of the pulleys, use of an incorrect belt, and/or there is a heavy resistance (bad or dry bearings).
Old 06-01-2023, 08:47 AM
ironman's Avatar
ironman ironman is offline
You should go to these two links and read the manuals....
http://ccmanuals.info/pdf/70-100%20O...r%20Manual.pdf
http://ccmanuals.info/pdf/Pin%20On%2...s%20Manual.pdf
Old 06-01-2023, 10:55 PM
LAWN BOY's Avatar
Default Thanks R Bedell
Thank you for the info R Bedell. Turns out that I was missing the mule drive belt completely and it was just the spindle belt that snapped. I just ordered the belts.
Old 06-02-2023, 09:24 AM
Does your 70 have the quick attach as shown in the above example?
Old 06-02-2023, 10:40 AM
LAWN BOY's Avatar
If I’m looking at it right, yes.
