Old 10-22-2022, 07:15 PM
backswampcub backswampcub is offline
Default 3 digit O
I picked this up this morning as a parts unit for my early 4 digit collar spindle restoration. I was after the lift assembly and for the $100 I paid it was worth it for the lift. After getting home I found it to be a three digit cub. It came with a Briggs engine in it which will fit one of my Sears Suburban projects. But now that I realize it’s a 3 digit I hate to part it out. But I really just have a dash tower, Frame and a Tranny at this point and a lot to chase down. I know a lot of 3 digits were pull starts but at which serial did the electric starts begin.
Old 10-22-2022, 07:36 PM
CubDieselFan's Avatar
I would hate to part it too. Build it and find another lift. 3 digit O’s are worth more than what the lift is worth.
Old 10-22-2022, 07:43 PM
My 4 digit is fully disassembled and has the early rims. Basically I need to choose which one to restore as between the two of them I can complete one at this time. Really just stuck on the start system. Should I use the starter or try and track a pull start setup.
Old 10-23-2022, 05:32 AM
I had #994 and it was electric start so not all 3 digits were "yank to crank" motors.
I got a 63 roller Original with rear lift, spring assist & deck.....
Old 10-23-2022, 07:11 AM
Good find. I would NOT part that tractor out. If it were mine, I would go into full restoration.
Old 10-23-2022, 10:32 AM
Look like a thin axle on it too, very sought after for that 3 digit restoration. All you need is a hood, grill, motor, and such. We have a complete pull start engine....
Up to 530 and counting...
Old 10-23-2022, 01:24 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Cool
This three digit O, unit number 734 purportedly came with recoil start, but was converted to electric
https://www.onlycubcadets.net/forum/...hlight=3+digit
Info on number 841
https://www.onlycubcadets.net/forum/...digit+original
Info on number 653
Info on 548
https://www.onlycubcadets.net/forum/...nal#post167627
Info on 624
https://www.onlycubcadets.net/forum/...nal#post139754
Info on 796. Purportedly came with a recoil start, and was upgraded to electric at the dealer
76x info-had recoil
https://www.onlycubcadets.net/forum/...3&postcount=13
3 digit info
https://www.onlycubcadets.net/forum/...inal#post68593
680 and 683
https://www.ihcubcadet.com/threads/f...99/post-246339
Info on 786 and 794, plus a few others
Info on 637
https://www.youtube.com/watch?v=ZQMHMag9W_M
Old 10-23-2022, 09:29 PM
Well without the original motor hard for me to know whether mine was electric or recoil. I can say there are holes in the tower for the ignition and the starter button. But I assume they all had that.
Old 10-23-2022, 09:54 PM
Does it have a choke knob?
Old 10-23-2022, 10:26 PM
Thin axel? I have a early 4 digit and understand that collar spindles and no hole tower lack of creeper holes but what is meant by thin axle?
