Old 10-18-2022, 04:05 PM
Ambush Ambush is offline
Default 682 with Deck and Tiller
I may go look at a 682 and I'm just wondering, first of all, if it's a good machine overall. Is the design user friendly? Are there any outstanding mechanical issues particular to this unit? High maintenance areas? What should I look for as far as trouble spots. The deck is lifted electrically and he says the tiller is a "screw lift" There are no side panels, but I think that is common.
Not sure about any hydraulics on the machine.
It's a 400 mile drive to pick it up, but I can combine that with some family visiting, so no big deal. It's just that I can't it see in person unless I go.
Old 10-18-2022, 04:52 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Cool
It appear to be an IH built machine, so it will have a cast iron rear. The original engine would have been a Series I KT17, which is marginal at best. Many were replaced with a better Series II. I find the 82 series to be one of the best IH sold overall. They are easy to work on, they are mostly steel/metal construction, and strong. Parts are easy to find, but many think they are made from platinum. Originally the 682 had a long manual lift lever for the implements. Optional was a spring lift assist. The only hydraulics on a stock 682 was the transaxle hydro unit, which is the unported variety.
Old 10-18-2022, 04:55 PM
Farmall450's Avatar
Yes, unfortunately. I would rec'd finding side panels, they should have them for operation (airflow/ducting, among other things).
Old 10-18-2022, 05:57 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The deck appears to be a cobble job of maybe two MTD decks. The original lift system was non hydraulic AND non electric...a time proven manual lift. Unless it is very cheap, I would not consider this particular rig.
Queen Of The Quietlines!
Old 10-18-2022, 07:13 PM
Make sure you get the front mule drive for the tiller and the long belt.
That belt will set you back more than you want to spend if it is missing are badly worn.
Also looks like the rear pulley guard is missing.
Myself, I'd look for s 1650 or a 1450 as they came standard with hydraulic lift
Good luck!
Old 10-18-2022, 08:43 PM
Farmall450's Avatar
Good luck!
Or a 782
To be fair, the default engine isn't great, but if they've lasted this long
Old 10-18-2022, 10:16 PM
1711Cub's Avatar
Originally Posted by Farmall450 View Post
Or a 782
Personal preference, but would never get a Quietline over an 82 series. Not a fan of the K361 or the Iso-mounts on those.
Old 10-19-2022, 12:35 AM
The seller sent a video of the tractor running and one of the tiller running. That's not to say that the tiller belt and pulleys are in good shape. I don't need a mower. Being non-ported is a big deficit.
I will heed the advice the Experts have offered and pass on this tractor. Cubs are rare and expensive here in the north west of Canada. A good, complete runner can sell between $1,000 to $2,500.
Thanks Guys and Gal !!
