Old 06-05-2022, 08:04 PM
Nessmuck's Avatar
Nessmuck Nessmuck is offline
Default 149 hydro speed limit?
Ran it finally today. It seems to have 3 speeds, not, kinda and holy cow!
How do I adjust it to be more between not and normally kinda slow?
Old 06-05-2022, 09:58 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Interesting Read: https://www.onlycubcadets.net/forum/...ead.php?t=4635
Plow blade
#2 Cart
QA36 snowthower
Old 06-05-2022, 11:15 PM
Nessmuck's Avatar
Thank you.
Old 06-06-2022, 04:26 PM
Nessmuck's Avatar
The parts look ok, but do wobble left and right. Is that normal?/
Old 06-06-2022, 05:19 PM
Nessmuck's Avatar
https://photos.app.goo.gl/Ew1s4upmKY7ZmApc9
Old 06-06-2022, 09:24 PM
Billy-O's Avatar
The trunnion plates do look a bit loose, but I think the springs are too loose or weak. Hard to tell in video. I also wonder if you have all the pieces for the trunnion spring... I see two springs and I cannot tell whether if you have both end caps. I think I see one, but can't tell on the other end of springs (towards the rear).
Plow blade
#2 Cart
QA36 snowthower
Old 06-07-2022, 12:16 PM
Nessmuck's Avatar
I appreciate that, I'll check.
Cub Cadet 149.
Snapper 1650.
Old 06-08-2022, 01:17 PM
Nessmuck's Avatar
The spring have both caps, but are loose for and aft. About and 1/8-1/4 of slop. Do I need new springs?
How would I fix the left-right wobble?
Cub Cadet 149.
Snapper 1650.
Old 06-08-2022, 04:49 PM
Nessmuck's Avatar
My mistake. Not for and aft, starboard and port. Left/Right. I remembered wrong. Definitely a lot of left / right play when it's all added up.
Cub Cadet 149.
Snapper 1650.
Old 06-08-2022, 06:44 PM
Are the caps badly worn into the sides of the trunion slot?
If so, you need a new repair plate
Hydro Trunion Repair Slot
Repair your worn trunion slot without removing the arm from the tractor.
Use this piece to mark your old one, cut it off and weld this one in it's place.
