I’m going to rewire my 125 since the engine will be out and at the machine shop. I would like to rewire it and install a new ignition switch. I found a replacement switch on isavetractors, but not the starting solenoid (electromagnetic switch). Is there a part number that you guys would suggest? For wire, I’m considering #10 THHN on the battery and starting circuits and #14 THHN everywhere else. Will these wire sizes be sufficient? My IH or Kohler shop manual doesn’t specify what wire size was original. I found an illustration online, but is there a link or picture on this forum so I know it’s accurate? Thanks in advance, Jay
Your wiring sizes looks to be very light (too small!!!!) Especially for the battery. I have not done any research, but.....
.....I suggest you get yourself a new wiring harness...Porch Electric makes them. http://www.porchelectric.com/ihcub.php
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
For General Wiring, I use 14 MTW (Machine Tool Wire). Don't like THHN, in that it is, too stiff to work with.
4 Gauge is more in line with Battery Cables.
Thanks for the info, I was planning on taking lots of pictures then laying out the old harness on my workbench. Then, just replace one wire at a time to minimize mistakes. I’m sure my local electrical supply house or big box home improvement store has the MTW you mentioned. I just have easy, free access to THHN. Does the THHN have the same current carrying capabilities as MTW?
MTW may be a little hard to find. THHN will work just fine, it just has the plastic sheath that makes it a bit stiffer.
I was originally going down the same path for my Cub 147, but by the time I considered the different gauges required, all the end connectors and then thought about years down the road not having the proper color codes, decided to go with a new one.
Completely agree with Billy-O and going with a replacement from Porch Electric. They are fantastic folks to deal with. |
I bookmarked their website.
Honestly, I have found beautiful unmolested wiring harness for sale that were plug in and play. More power to ya making your own.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
Are you referring to Porch Electric? I am probably going to go that route.
Porch Electric......... http://www.porchelectric.com/
