Old 07-08-2021, 08:18 PM
ICOM 756 ICOM 756 is offline
Default Carb bowl and tank bowl
OK, I see all the rebuild kits, with a float with the needle valve, and gasket so on ..
Where can I get just the gasket ??? for the bowl. I bought a brand new carb. after getting more run time thru the tank. Crap got in the carb bowl. I now have a external filter inline. but the bowl WONT stop leaking. Yes, I took carb off to put bowl back on no change. that gasket is thinner then paper and i think there might a cut in it... that I am not able to see.
Sooo, carb bowl gaskets.
and gas tank bowl gaskets to. Not able to find them without buying the whole thing.
K301 block. I don't remember name of carb if web or carter.. but the standard carb for the Kohler 300 line.
Old 07-08-2021, 09:00 PM
(A) I don't know if you can buy the gasket alone. If you could, it may be more than the kit.
(B) It DOES make a difference if the Carb is a Kohler, Walbro, or a Chinese Unit.
Old 07-08-2021, 09:24 PM
mortten mortten is offline
If it is a Kohler carb the part number is KH-200375S and available many places.
Doug
QA-36A
42" blade
Old 07-08-2021, 10:30 PM
RLause's Avatar
RLause RLause is offline
Sounds to me like the float valve may have something keeping it from closing and flooding the carb.
Richard
Old 07-08-2021, 11:20 PM
not flooding... leaking... from around bowl. towel put in front of throat to see..
its the gasket.
Thanks Mortten. That's one of them. Only one carb off orig Kohlers had that gasket. The other 2 have the half gasket with the thin ring.
it is the gasket on right. But like Bedell said who knows?
Bedell both orig on Kohler and chopsticks. Both types of gaskets came off carbs I have.
Old 07-09-2021, 09:45 AM
Do you have both gaskets in place??
Old 07-09-2021, 01:18 PM
The gasket on the right is KH-25-041-02
Doug
QA-36A
42" blade
Old 07-11-2021, 12:09 PM
this is aftermarket it only had the one gasket. never seen anything have 2 gaskets in one place.. there would be movement..
ty Mortten... ill check see if i can find it ...
Old 07-11-2021, 12:18 PM
Best to find out just WTH carb you DO have
A picture would help
If its a chinese knock off you will likely find the float valve seat to be an off thread as well.
I'm done with this one.
Old 07-11-2021, 12:37 PM
Walbro carbs only have one gasket.
