I was rebuilding 147 steering column on work bench. Took it apart cleaning in pans. Then sat for awhile somehow I misplaced screw in plug at bottom of column. I've looked everywhere, 2 and 3 times, the shop 'ferries' must of needed one.. Went to dealer got all other parts but no plug. Checked advertisers nothing unavailable. Anyone have one they would sell? Thanks.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Our Sponsor CC Specialties has them. See: https://ccspecialties.org/steering_seats.html towards the bottom of the page.
Just thinking out loud hear... But that plug should be standard pipe threads, so why not figure out the size needed (maybe someone knows off the top of their head) and go to Fastenal, Grainger, HD, Lowes etc and get a pipe plug for a couple of bucks max, verses $10.00 - $20.00 for one. Just throwing that it there.
But then again I could be totally wrong.
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Problem with that is, the plug that they came with has a bunch of deep slots in it so that it can be held in place with a cotter pin, so that it doesn't fall out. It just sits loosely in there, you don't tighten it against anything, so the cotter pin is needed to hold it in place.
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
I see, same principle like the nuts on the front drum/wheel bearings back in the day. Man I don't miss having drum brakes on all 4 corners. ![]() I looked at the plug pic from IHCCW, and thought that it might just be a generic pipe thread plug. Thanks for the explanation.
It's not just a plug!
It's a machined retainer and adjuster for the bearings and worm gear shaft. |
I need the one with all the slots,so as to lock with the pin. Ckd all the advertisers cant seem to find it per part number,and plug,not listed from what I've seen. Or its saying not available. Maybe someone is better at finding part. Thank you for all the info. I thought about a plumbing part.
About 3/4 down on this page.
https://www.ccspecialties.org/steering_seats.html Quote:
Thread the cotter pin hole and put a set screw in.
