Old 01-31-2021, 03:56 AM
ICOM 756 ICOM 756 is offline
Default To torque, or not to torque
I rebuilt a k301. I did the 30 backed off then retorqued to 24 fp on the Connecting Rod. Well I messed up and motor had some grit in it, and was getting to much metal in oil. So I pulled it apart, and hope I fixed it with a good hot soap bath.
anyways...
Being the rod was torque to 30 already, do I need to retorque to 30 then 24, or just to 24fp ??
Old 01-31-2021, 04:13 AM
Bryan S Bryan S is offline
anyways...
The reason for the torque to x then back off the nut, then re-torque to x is for when you put a new rod/s in an engine, and one would hope, that new bolts were used as well but... people are cheap, and some are in a really big hurry. It's done to help eliminate rod bolt stretch.
If your bolt was new, and you did it the first time, you do not need to do it again. HTH
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 01-31-2021, 08:51 AM
Any new rods I have bought that were in rebuild kits already have the new correct bolts for that application.
Old 01-31-2021, 09:58 AM
Always, always,.....
wash a rebored block with hot soapy water to get the fine honing particles out of the engine, paying special attention to the cylinder bore.
I wash a block first with gas to get any remaining contamination out, blow with airhose then the hotsoap water, followed again with a the air hose to dry the block. Small instant rust is of no concern to the bore,after drying. if not going to assemble, soon, do coat the cyl wall with oil and cover with plastic to prevent contamination. If you are getting contamination in the crankcase, do a through cleaning and inspect the cylinder/crankshaft for damage, from it Clean the piston and ring groove area.
Assembly of an engine cannot be too clean.
Old 01-31-2021, 01:44 PM
Yep, that's what I was thinking. It's the pre-stretch. Yes, was new rod and bolts from Isave.
Old 01-31-2021, 01:53 PM
ya know i thought i had it clean. but nope lol brake clean and new rags dont work lol ...
it got on the crank side of rod. grrrrr but i was watchin oil and maybe 3 hours total on it.. 2 oil changes. i feel i have the rod back.
the piston has the scuf marks 90degrees off the wrist pin sides. only 2 spots. cam lifters seem untouched thank god lol
i called the shop up. he said same with hot soapy water lol think i would have known this .. grrr
i used 1000 grit on the rod . very little bit.
pix below nail doesnt catch anything in cycl not touched it yet... rod is cleaned up but this is what i looked like grrrr
i did have the rod hole towards the cam for the oil.. lol
Old 01-31-2021, 05:23 PM
Yes that is debris scuffing.
Actually after a gas bath, I hit them with the garden hose, then the air hose, then visually see if I missed something then the hot soapy water bath.
and the air hose again.
Check the crankcase breather as well as the valve spring area.
Every crack and cranny has to he clean.
Good news is, I don't see and real damage to be of concern.
Old 01-31-2021, 09:17 PM
good news so far ... ty
iam thinking few things came togther..
iam puttin them in here incase someone comes across this and hope it helps them
1st and for most NEVER DO THIS with eyes closed at midnite ...
as ol'George says.. follow what he said above...
do it twice .. never can be to clean
i think even tho i had rags in the ports stuffed around stems to keep the grit from compound out of the guides. some still got there... somewhere...
again CLEAN THE MOTOR like ol'george says
hope my stupid mistake helps others.. not to make it ..
bad part no heat in shop so warmer weather..
ol'george what do we use for the valve cover filter? i meen what 7 bucks i think i seen them for a 1 inch sq of filter.. thats crazy..
buck n half maybe 2 bucks but 5 and above is nuts lol
Old 02-01-2021, 08:56 AM
I have used a bit of stainless steel scrub pads before.
Worked for me
Old 02-01-2021, 10:21 AM
scrub pads work as mentioned, hog hair works also.
The idea is to slow/catch oil particles so they don't get directly spit out with a puff of crankcase air.
Those little filters are prolly a 500% profit, smaller than a match book cover.
I would think nothing that would melt from temperature or nothing that would
dissolve from petroleum oils would be appropriate.
I've seem washable furnace filters that would work.
