Old 01-25-2021, 12:54 PM
DSarow DSarow is online now
Default Keeping Choke and Throttle Cables lubed and free
I have a cub 125 that doesn't get used much. What is a good technique and lube to use to free up the cables? Then a lube to keep free? Thanks.
Old 01-25-2021, 01:03 PM
longislandcubs longislandcubs is offline
I use a product called Kroil Penetrating oil..Its sold at most auto part stores and on Amazon. It is much better in my opinion then WD-40. I spray both ends of the cables while I work it in..Doesnt "run" as much as other lubricants.. Good luck.
Old 01-25-2021, 02:41 PM
I use PB Blaster. Similar to Kroil, with very good results.
Old 01-25-2021, 03:05 PM
Depending, if they are just kinda tight or stuck I use the PB as well. If
they are working well and I am just in the maintenance mode, this is always
the goal. I simply use a light weight oil such as 3 n 1. I like to take them
out of the tractor, hang em with the control side up and put a little lube
between the cable and the sheath, let it soak. Keep putting more in till it
you get some coming out the other end. I always put the control side up
so any crud comes out of the cable and not back towards the control side.
Have had old neglected stuff that has taken a day or two to get going but
with patience you can free up most any cable.
Ken
Old 01-26-2021, 09:33 AM
charlie105's Avatar
charlie105 charlie105 is offline
Default Cable lube
I use a motorcycle cable lubrication tool with Aerosol lubricants. Google “motorcycle cable lubrication tool”. $5-$10. It will drive lube from one end and out the other.
Old 01-26-2021, 07:13 PM
RLause's Avatar
RLause RLause is offline
Awhile back I had 2 Cubs that spent a lot of time in the weather. It was rusted solid where it went through the dash. The part that attaches to the dash has a slit in the one side that I was able to pry open slightly and apply pb. After a lot of tapping, I was able to move the core. Then some brushing, sanding and squeezing it back together, it worked like a new one.
Richard
Old 01-26-2021, 10:31 PM
What will they come up with next. Not that I mind spending several days
freeing up a cable but that's pretty cool.
Ken
Old 01-27-2021, 11:52 AM
charlie105's Avatar
They have been around for at least 25 years. Mostly appropriate for the older motorcycles with cable operated systems. Hydraulics have replaced the cables on many machines.
Old 01-27-2021, 10:00 PM
Good to know I am keeping up. Always been a lot happier being 20 or
so years behind.
Ken
Old 01-27-2021, 10:42 PM
Cubcadet_107's Avatar
Okay, so you've all got it covered when the linkage freezes from rust. But what if it freezes from the cold?
When this happens it's usually the result of water freezing in your cable and/or linkage. To solve this issue, although you should stray away from it if the issue is rust related, the best product to use in this situation is actually WD40. The "WD" quite simply stands for "water dispersant" and it'll do a pretty good job keeping any water outta your cable and linkage.
Just some food for thought for ya's
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
