I just finished adding bumpers to both of my Cubs that serve mower duty. The bumper on the 1811 is an original Cyclops part number 190-398-100 bumper. The one on my 782 is a 2000 series bumper part number 190-298-100 modified with brackets made by me to duplicate the much more expensive and harder to find bumper.
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
More pics..
Last photo - the original.
Good job!
It appears from the photos that the (2) round tubes that run from the bumper to the brackets are welded onto the brackets, but the first pic of the brackets look like they're attached with a bolt/nut to a flange. Is the bumper welded to the brackets or bolted?
Stanton 1980 IH 782, Kohler M18 IH #1 Cart, original IH 42" Blade, modified to 50" and hydraulic 2015 XT2, Kawasaki 23 HP |
![]() Quote:
The bumper is welded to the tubes, and to the brackets. The only bolts involved are the bumper brackets to tractor frame, which are 1/2"-13 x 1.5" long with a lock washer-one per side.
What I started out with. I loped off the two frame brackets, and ground old welds on the bumper smooth..
![]() Quote:
For my 2182 (biggest concern, plastics) I scored a NOS in box MTD 190-672-190 or OEM-190-672 SR for $50, which while having different brackets, is spaced right to bolt on. Might have to trim some bracket back for other functionality.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Thanks for posting the part number of the newer bumper. Looks like a great alternative.
![]() Quote:
