Old 05-02-2020, 02:35 PM
Rbertalotto Rbertalotto is offline
Default Super Easy way to add OIL Temp Gauge to 782
I bought a tree gauge set for my 782. Voltage, Oil Pressure and Temp....
Install and hook up of Voltage was just two wires....My engine is a Kohler KT-17s II so it has a place for an oil pressure sender......but the Temperature gauge is really meant for a water cooled engine.
I wanted to read Oil Temperature with it.
Someone suggested that I figure out a way to connect it to the oil drain plug....Great Idea!
Upon opening the package I found three brass adapters......And one of them fit the oil drain hole PERFECTLY!
The temperature sender simply screws into the adapter and DONE!
I rant the steel covered tubing under the engine and up to the gauge. Next time I have the welder out I'm going to weld something on the bottom of the engine mount to protect this tube. Maybe just a piece of inverted angle iron.
I'm amazed at how cool these engines run. I idled it for about 15-20 minutes before the gauge even started to register. (It starts at 100 degrees). I thought it might be inoperative so I checked the area of the drain plug with a laser thermometer. Was still under 100 degrees. Finally it started to move but at 120 degrees I had to leave so I'm not sure how hot the oil actually gets. And I'm sure it gets a lot hotter when working.
Old 05-04-2020, 11:00 AM
goonpeden goonpeden is offline
Looks Good!
Old 05-04-2020, 02:38 PM
CubDieselFan's Avatar
What is the max oil temp you have seen so far?
Old 05-04-2020, 04:05 PM
150 degrees after driving around for 30-40 minutes. Not working hard, just driving around. Confirmed temperature with a laser thermometer
Old 05-04-2020, 05:33 PM
Interesting, I thought it would have been more than that. Good info. I have thought about adding a small oil cooler to one of my 1872’s.
