Old 11-22-2020, 07:13 PM
CubbyRI CubbyRI is offline
Default Is this a ported pump?
I was thinking about making a hydro build for a few things. Would be nice to use a ported pump although I dont know how much accessories that can run. (Bucket loader?)
Anyway, is this rear a ported pump?
Thanks!
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 11-22-2020, 07:51 PM
Thanks!
I'd say no, but the ports would be hidden by the curved suction line in the photo.
It also appears to be the factory oil filter, as all the new replacements do not have a canister filter, they are throwaway spin on like we are used to seeing the last 50 years.
You are not going to operate much hyd equipment with about 4 GPM's full throttle.
Admittedly, you can operate a front loader, but it will be painfully slow
in my opinion.
The "return loop" of the Hydro pictured, hides the areas of where the "ports" would be.
Old 11-22-2020, 07:56 PM
Thanks guys. Yeah I figured I'd need a separate bigger pump for a loader. I was thinking about an old car power steering pump actually. Got to check the psi and gpm. What are good numbers for those to run a loader with also a bucket tilt cylinder?
Gonna fab the loader myself
Old 11-23-2020, 06:38 AM
Here is what I used on my Kwik Way FEL on the 1772 and it works well.
https://www.northerntool.com/shop/to...9706_200329706
Old 11-23-2020, 11:31 PM
sawdustdad's Avatar
You will want a pump with about 6 gpm at 3000 psi for a satisfyingly snappy loader. You may want a 1500 to 2000 relief valve in the system, but the 6 gpm is a good rule of thumb.
Old 11-23-2020, 11:50 PM
Cool thanks. What does the relief valve do?
also, Im liking this design, only 2 cylinders needed, and can buy plans too
https://www.loaderplans.com/order-ca...nd-loader#mini
Old 11-24-2020, 08:16 AM
A pressure relief valve keeps the desired pressure in the system.
Without one, there is nothing to control the pressure causing things to break,
like hoses, lines, pumps, etc.
Much like the pressure regulator on a propane grill, or an air compressor.
Old 11-24-2020, 10:15 AM
Ambush Ambush is offline
A relief valve is the one component in a hydraulic system that everybody can find to "turn up" the pressure limit. Usually believing it will compensate for a weak pump or motor. It's also the component that they fail to reset after finally installing a new pump or motor and subsequently destroy the new unit or blow all the old weak hoses. The latter being preferable.
Tales From the Shop.
Old 11-24-2020, 12:15 PM
Cool
so how does one "reset" a pressure relief valve?
and, would this control work? says it has a pressure relief in it... and if I have a 3500lb pump, does this 2000 press relief mean I am actually limited to 2000psi at the hydraulic cylinders?
https://northernhydraulics.net/catal...g3000-668.html
