Old 08-28-2019, 06:45 PM
RedHawCadet RedHawCadet is offline
Default Cub 2B tiller
Hey guys been a long time. I recently moved and I'm in the process of trying to put in my yard. I just bought a 124 with a 2B rototiller. I dropped it in the ground, not fully made a pass. Then the tines quit. Everything else turns. Is this a shear bolt? I grab the tines and they turn about a quarter turn and stop, they don't turn completely like there's no resistance. Did one of the gears shear a key? Thanks in advance.
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 08-28-2019, 07:14 PM
Sounds like you broke a chain.
Old 08-28-2019, 08:08 PM
The #2B Tiller was designed for the 82 Series tractors using the 5/8" drive belt. Might have to change the drive pulley back to 3/8" to run the tiller correctly. That is if it already hasn't.
Old 08-28-2019, 09:06 PM
Thanks for the replies guys. The 90 degree box that is on the tractor is for a 3/8's belt. So I think it has been changed. The PO said something about it having another 90 degree box? So I'm guessing the tines won't turn because like Sam said the chain may be broke and is laying in the bottom not letting it turn?
Mark
QA42 snow thrower
42in front blade
Old 08-28-2019, 09:16 PM
It does have a 3/8's pulley on if now.
Mark
QA42 snow thrower
42in front blade
Old 08-29-2019, 05:57 AM
With the tiller up in the air and the belts off see if you can spin the big pulley by hand and if the tines turn.
Old 08-29-2019, 06:54 AM
The pulley turns freely. The tines don't turn. I'm taking it to work today to open it up.
Mark
QA42 snow thrower
42in front blade
Old 08-29-2019, 08:17 AM
If yer tines don't tine, and yer pulley don't pull,
yer chip monks are not holding hands inside,prolly because of no peanut oil
Old 08-29-2019, 06:37 PM
So pulled the whole dang thing apart today. The chain was broke and had multiple other splits at the ends of the links just waiting to let loose. I cleaned it all out in the solvent tank and put a new chain on. Everything else looked to be workable. I'm going to put her back in the ground tommorow! Thanks for all the replies!
Mark
QA42 snow thrower
42in front blade
Old 08-29-2019, 07:00 PM
don't forget to oil dem chipmunks
