Old 01-08-2020, 12:44 PM
Kelpie's Avatar
Kelpie Kelpie is offline
Default Transmission Whine
My Model 70 has a whine in the transmission when it is in gear. I haven't used it much since the whine started.
Any ideas on what it could be? It doesn't make any noise in neutral. I have a creeper and have checked fluid levels, which check out fine.
1964 Model 70 that Dad bought new. Lights, fenders, creeper, 38 inch deck, Brinly plow, sleeve hitch, and lift assist.
Old 01-08-2020, 01:37 PM
green407's Avatar
green407 green407 is offline
I'm no mechanic, but... does it whine when the creeper is in low range also or just in high range? Does it whine in all gears? Is the whine louder in one particular gear or is it about the same in all gears?
128 X 2, 129, 149, 1250, 1450 x 2
Old 01-08-2020, 09:36 PM
What transmission fluid are you using and how old is it ??
Old 01-08-2020, 11:17 PM
Another question to consider....Is the whine in the transmission or is it in the creepy gear or is it in the driveline or clutch?
Old 01-09-2020, 09:34 AM
Kelpie's Avatar
I have newer hytrans in the rear end as well as the creeper. Doesn't matter if it is in high or low on the creeper. It also doesn't matter what gear the tractor is in.
The fluid is at the proper level and not low.
It only whines when the tractor is moving. If it is out of gear with the shaft spinning, it does not whine.
It sounds like its in the transaxle.
I was told it may be the bearings in the countershaft.
Old 01-09-2020, 01:50 PM
green407's Avatar
I don't think it's one of the counter shaft bearing, the counter shaft speed changes with the gear selected and then so would the whine. If it does it in both low and high range I don't think it's the creeper gear. So now we're left with the main shaft bearing, the reduction gear bearings, and the redudtion gears themselves. If it's none of those the only other thing I can think of is the clutch release bearing.
Old 01-09-2020, 07:05 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
usually when you get a whine like that its ring and pinion setup
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 01-15-2020, 11:51 AM
Kelpie's Avatar
Ok. So I assume to figure it out, I'll have to tear into the transaxle. Will any of these theories have something obvious to check while its apart?
Old 01-15-2020, 06:37 PM
green407's Avatar
Here are a few photo's of what to look for, some of these are extremely worn, but I hope it gets the point across. These are just examples
Old 01-15-2020, 08:29 PM
jbrewer's Avatar
jbrewer jbrewer is offline
What in the world pitted those gear teeth? Rust?
I'd surely replace the bearings, but given that we're dealing with a garden tractor not a land speed record vehicle, I'd use that ring/pinion set and not give it a 2nd thought.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
