Old 07-22-2010, 06:07 PM
dale.l dale.l is offline
Default creeper strengh
will a creeper hold up to plowing a garden a couple time a year and pushing snow? I will not use low for any kind of load work, only to slow the tractor down for tilling. do you have a creeper on your plow tractor if so have you had any problems?
Old 07-22-2010, 06:33 PM
jbollis's Avatar
jbollis jbollis is offline
I answered you on the other forum.
Sold everything but one.
Old 07-22-2010, 08:35 PM
The Cub Cadet creeper gear isn't so much a "Hi/Low" feature as it is an "On/Off" feature.
When in "HI" it's more like the creeper is turned off, kinda like, low is bypassed or disengaged. Therefore there isn't the same force or pressure (however you want to say it) against the more delicate inner parts (planitary gears and carrier). Hi isn't really high at all, hi is just "normal"
When in "LO" ALL of the pressure/force is applied to the more delicate working parts. If you aren't trying to move a heavy load, nothing is hurt, but if you're trying to pull a plow you're gonna break it. It isn't designed for power it's desinged to reduce the RPM's into the transmission.
So if you have a creeper, yes, you can pull your plow while in "HI"
Old 07-22-2010, 08:53 PM
I understand low is not designed for pulling, I just want to make sure Im not going damage it plowing in HI 1:1. I would think International would have thought that a tractor with a creeper for a tiller would also be used to plow a garden with
