Old 07-16-2021, 03:26 PM
Esand323 Esand323 is offline
Default Hydro Relief Valve - struggling to remove
Hi all,
I have a 1450 Cub Cadet. I've noticed transmission oil leaking and found that it was coming from the hydro relief valve. I'm looking to replace this valve but I need to remove it. I'm really struggling to remove this. I've been trying to turn the valve counter clockwise with a wrench but it does not want to budge at all. Any ideas or suggestions?
Old 07-16-2021, 04:07 PM
Pitch that farmer wrench, good way to really skin some knuckles, and use the correct size 1" box end wrench or socket and breaker bar so you can get some decent leverage.
Make sure the area surrounding the valve is spotlessly clean using carb or brake cleaner and blow dry w/air. You may even need to use a small wire brush in the process as well. You DO NOT want crap falling back inside the housing while removing the valves.
You may have rap the end of the wrench with a hammer a bit while applying some pressure.
Old 08-02-2021, 09:35 AM
MitchJ MitchJ is offline
Exactly what he said. I had the same issue, just a good wrench, and a good wrap from a hammer
