I don’t know what you guys use on the nut on the bottom of the Ross Steering box, but I have found it difficult, because even my widest screwdriver is not wide enough to turn it without messing up the slot. I took an old socket to my welder buddy and had him weld a plate onto it, so now I have a socket to use on my ratchet wrench. I hope that someone else can use this idea to simplify their process!! (Wasn't sure which area to put this in)
David North Carolina |
I use a drag link socket.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Scrap of flat bar stock and a vice grip, or a flat washer ground off on one edge.
I have never ran across one that didn't turn out easily though. mostly use the tool to seat the bearings for initial adjustment. |
Good homemade tools are a lifesaver. As mentioned above, a drag link socket is the tool you would need to buy if you couldn't make something. Here's what they look like ---
https://www.zoro.com/proto-drag-link...CABEgLjePD_BwE
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
