Does a 149 use a fuel sediment bowl like a narrow frame?
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
No, it uses a non sediment bowl.
Thanks Lew and Alvy. Is there any kind of filter?
That is a cylindrical fine mesh screen on the end of that petcock fitting. It protrudes up into the tank and acts as the filter.
Ok, thanks.
So is any fuel filter necessary other than that screen? I have a non cub with a K321 in it with gas tank on top, I put a filter on it because I thought it couldn’t hurt. I’ve found that it seems to “run out of gas” with gas still in the tank. If I keep it above about 1/4 tank it does fine. I was thinking maybe the filter is too restrictive.
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
I'm thinking you are thinking right.
There are filters that are for gravity flow systems, mostly they are just a screen. The other type are more restrictive paper types and are for systems that have fuel pumps. When you remove the fitting @ the carburetor, it should piddle out quite well, not a weak dribble. |
I ran a 108 with only the petcock filter screen in the tank for over 30 years. In that time, I had the screen clog up one time, early in my ownership of the tractor, but once I removed and cleaned it, it never clogged again, nor did I ever have any dirty fuel issues.
I've also used pleated paper in line fuel filters on these tractors with no issues. Fuel feeds fine through them via gravity. I don't usually let the tanks get below 1/4 full, so maybe if I did it would make a difference. But to answer your question, the petcock screen filter is all you need.
I agree, I've run these for 40 + years and never had a fuel issue with the screen in the tank getting clogged, but I am a little anal about keeping my fuel cans clean and not getting dirt in when I'm gassing up !
