Old 04-29-2018, 08:00 AM
drcjv's Avatar
drcjv drcjv is offline
Default Help with mower
I have not been doing much with cubs lately as I have said due to some health issues. Yesterday was nice out so I though I would try some mowing on my 2072 . When It would get under load the deck would slow and even stop spinning. If I would slow down or stop it would start spinning again. I do not think the belt was slipping as I did not see any smoke or smell any burning. Any thoughts would be appreciated. I can't really get down and dirty trying to fix it right now but might be able to walk my son through it.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 04-29-2018, 08:57 AM
Something is definitely "slipping". Possibilties are: (a) worn belt, (b) worn pulley(s), (c) deck belt tensioner not working, and (d) PTO clutch slipping.
Old 04-29-2018, 09:29 AM
I vote for (c).
Old 04-29-2018, 09:57 AM
Billy-O's Avatar
Billy-O Billy-O is offline
All good possibilities mentioned. I'd like to add that I had a blade come loose on a spindle. Probably hit a stump on one blade that stopped the deck and it loosened the other.
Plow blade
#2 Cart
QA36 snowthower
Old 04-29-2018, 10:03 AM
drcjv's Avatar
Roland what is the best way to narrow it down
2072 50" deck
Old 04-29-2018, 10:11 AM
Visual observation on A, B, & C. Once the condition starts, one could get off the tractor and take a look at the PTO, if that is possible on your model. None the less, something is slipping.
Old 04-29-2018, 12:18 PM
drcjv's Avatar
I looked everything over and found that the one pully on the mule drive was all the way forward almost touching the front of the mule drive. I tightened the other side until they were even. If I am correct this is what puts tension on the drive belt. With it all the way forward I don't think there was much tension on the belt.
2072 50" deck
Old 04-29-2018, 12:27 PM
I think you found your problem. One of the Mule Drive Pulley's should be "spring loaded" applying constant tension.
Old 04-29-2018, 02:23 PM
drcjv's Avatar
I thought I had it too but no such luck. Is the deck drive belt the same on a 2072 and a 1572 or are they different that could be my problem. I took the deck off my 1572 and put it on the 2072. Also this 2072 has an iron rear. How do I check the hydro fluid there is no dip stick. I do see the plug on the back, is that where I check if so how much is good. I already did way more than I am supposed to so now I will have start again tomorrow.
2072 50" deck
Old 04-29-2018, 06:52 PM
john hall's Avatar
Sure you haven't broke a spring on the mule drive idler/tensioner or on the deck tensioner?
You asked about the oil level and having a cast iron rear. I don't know if you have the same rear as a 982, but those have a hidden dipstick that not a lot of folks know about. I think you access it by removing the small plate above the tunnel cover. It looks just like an engine diptstick IH used in tractor engines back in the 70's. Sorry about the pic quality, you can make out the dipstick just behind where the pump mounts
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
