Old 05-30-2018, 02:00 AM
fgaretired fgaretired is offline
Angry 127 Hydro Release Lever
Can anyone tell me which way the Hydro release flapper goes on a 127. I know the lever points down when not engaged. But does the curled end on the flapper go towards the front of the tractor or to the end of the tractor. I know somebody has probably ask this before.
Thanks
Glenn
Old 05-30-2018, 05:15 AM
First, welcome to OCC.....
The Hydro Release lever looks something like this image.
On the under side, the flapper is installed as to face the back of the tractor.
Old 05-30-2018, 08:05 AM
Put a piece of foam tape just above it to keep it from rattling.
Old 05-30-2018, 08:12 AM
ironman's Avatar
ironman ironman is offline
Thanks
Glenn
Don't have one to look at right now but if I recall correctly the rounded side of the flapper will come down and depress the buttons on top of the release valves when you lift up on the lever.
Old 05-30-2018, 11:48 PM
thanks the foam idea is a good idea. First total restore i have done see if i can post some pictures
Old 05-31-2018, 12:18 AM
Default The Start of it all
Heres the beginning IV bottle for a Gas tank lol
Old 05-31-2018, 12:24 AM
Weather around here has been rainy so have to work around the weather
Old 05-31-2018, 12:30 AM
Completely took the tank apart sandblasted it, patched the bung and soldered it back together. Red Coated it after it was finished.
Old 05-31-2018, 12:56 AM
You actually took the gas tank apart? Then soldered it back together..... and then put red coat in it?
If you can do that work, why would you need to put red coat in it? If it had a leak, just fix it.....
Even seen what red coat does when it flakes off? Nasty stuff.
Old 05-31-2018, 01:04 AM
it didn't leak i just want to keep it from rusting again. If you thin it with a stone and do a thin coat to keep it from rusting it wont peel. Most people get it on to thick and it peels. They don't let it dry long enough. By the time I put gas in it, it will be a year. lol
