Old 04-04-2018, 02:13 PM
Countryboy5191 Countryboy5191 is offline
Default 107 electric lift
I have a 107 and just picked up an electric lift for it, my questions are, how hard is it to make a 147 rockshaft work with the 107, and also what is needed to connect a snow blade lift rod to the electric lift. Just trying to get my ducks in a row before installing the lift.
Old 04-04-2018, 02:18 PM
The 107 and 147 are basically the same tractor so the rockshaft will go right in.
Old 04-04-2018, 02:19 PM
Thank you!
Old 04-04-2018, 06:32 PM
sir_lancealot sir_lancealot is offline
You will need to fab up a bracket for the front of the e-lift to attach to the frame. The 147 was built with the bracket on the frame flare. If you go to page 6 (PDF Page 11) of the below manual, it will tell you how to rework the implement bracket to work with the e-lift.
http://ccmanuals.info/pdf/Front%2042...l%20Manual.pdf
Old 04-05-2018, 06:26 PM
That's a good lookin' 107 there. Be careful getting that Armstrong lift out of it. Hint: Never cut what you can untie!!!
