Old 03-09-2017, 08:32 PM
Bigpadg Bigpadg is offline
Default LTX 1046 No Spark
No spark at all to either cylinder. Neither coil is firing does that mean the stator is the problem? I reseated the wire on the coils, battery good. Any help would be appreciated.
Old 03-09-2017, 08:55 PM
Default No spark
New here so any help
Appreciated. I guess both could could be bad. Where can I read on proper way to test them?
Old 03-09-2017, 08:57 PM
I meant to say both coils could be bad
Old 03-09-2017, 09:08 PM
Should have magnetos. Stator doesn't have anything to do with the ignition. Probably a bad safety switch.
Old 05-05-2018, 08:27 PM
ladycub ladycub is offline
Unhappy LTX 1046 no spark
I've read several times "could be a bad safety switch", how many safety switches are there and where are they if not the obvious ones? Can you test them with a multi-tester? I have a LT 1046 that I've been fighting with lately, and I suspect it's a safety switch or key switch, makes no noise when you turn key, no spark at plugs, have a new battery and solenoid. There just seems to be so many things that could cause it, I don't know where to start.
