Old 10-11-2022, 07:12 PM
Hydros Hydros is offline
Default IH 1450 Engine not turning over
Hello Forum,
Getting no reaction when turning ignition switch to start. This occurred a year ago & then again today. Battery is fully charged--lights turn on to full bright. When it happened last year I left it for a while then attempted a restart--cranked over & started right up. Earlier this year it was not charging, so I replaced regulator & checked all wiring which proved not the problem. Finally, replaced ignition switch (thanks to a tip on this forum) & that solved that issue.
Appreciate any input on this--unit is a 1974 model.
Thanks,
John
Old 10-11-2022, 07:38 PM
Check the solenoid to be sure it is being energized when turning the key to the start position.
Make sure you have power to the small terminal with the key in the start position. if you do, the issue is with the solenoid.
Try jumping across the 2 large posts.
It should crank.
Old 10-11-2022, 08:01 PM
Tom Dowling Tom Dowling is offline
Did you leave it out in the rain? Might be corrosion on the ignition switch terminals.
Old 10-11-2022, 08:03 PM
finsruskw thanks, I will give that a try tomorrow.
Old 10-11-2022, 08:05 PM
No, corrosion on ignition switch terms, thanks
Old 10-11-2022, 09:12 PM
Wild Bill's Avatar
Wild Bill Wild Bill is offline
The PTO switch must be off (electrically open), and the brake safety switch made (electrically closed) to complete the ignition circuit.
Is the spring metal flapper pushing down on the safety switch, when the brake pedal is latched down?
You need to check the PTO switch and safety switch with a VOM, to be sure. Sometimes they fail internally.
Original OCC Super Mod....and former OCC Co-Admin.
I was hacked........
Old 10-11-2022, 09:23 PM
Wild Bill's Avatar
Go to the:
Technical Library - Tractors
Click on:
Page 5
Scroll down to:
Wiring Diagrams - WF
The 1450 diagram is the bottom one.
Old 10-15-2022, 10:03 AM
Solenoid was the problem, cranked right over--thanks finsruskw!
