Old 03-18-2022, 07:50 AM
67flh's Avatar
67flh 67flh is offline
Default Respirators
For everyone that has used hardener in your paint. What type of respirator did you use. From what a gather it is very important to use one and I have actually seen where only air supplied respirators should be used.
Old 03-18-2022, 08:54 AM
Supplied air from an outside source are very good, but can get pricy.
For the hobbyist a good mask with FRESH charcoal canisters works for me.
Myself, I use NORTH brand, but others are just as good.
it is very important that one gets a tight fitting mask with no leakage.
With fresh approved canisters as one should, you will not smell the paint.
If you can smell it, either the seal is not good or you have the wrong canisters or they are old.
If one uses a surgical mask, paper dust mask or an N-95, you might as well use nothing.
----just my two cents.
Old 03-24-2022, 07:34 PM
I paint professionally and wear one of these.
https://www.amazon.com/6211PA1-Cartr.../dp/B00QZ5I4KW
Old 03-24-2022, 09:58 PM
Billy-O's Avatar
Billy-O Billy-O is offline
So do I, in woodworking using laquers, conversion varnish, etc.... Can't smell the solvents.
Plow blade
#2 Cart
QA36 snowthower
