Old 05-29-2010, 09:11 AM
cdlong's Avatar
cdlong cdlong is offline
Default 1450 hydro whinning
I got her running last night. I had a whine in the hydro. I checked the oil level this morning and added 2 qts of type F ATF, (PO told me that was what was in her). I still have the whine. Is this normal with a hydro? I've only had gear drives for the last 8 yrs or so.
Also, the handle that controls the front hydraulic ports won't stay centered. (If you remember, my hydraulics aren't working, the pins(?) in the valve box are stuck). Could this be the problem with the front port control lever, no pressure to keep it centered?
Thanks
Old 05-29-2010, 09:21 AM
MBounds's Avatar
MBounds MBounds is offline
CDL: Why don't you try using Hy-Tran (or Cub Cadet equivalent) which is what is supposed to be in there. Drain that alien stuff and do it right!! Don't forget to also put on a NEW Cub Cadet hydrostatic Filter!!
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
Old 05-29-2010, 12:00 PM
ajgross ajgross is offline
Inactive Member
Just beware that using fluids that are not spec'ed for that rear end could cause severe damage. The seals inside might not be meant for ATF and might begin to break down and fail.
AJ
Old 05-29-2010, 01:47 PM
cdlong's Avatar
That's PSG, (Armor), to you Sgt Major. (Small world, we're from New Caney,Tx orginally). Thanks for the advise folks. I only put the ATF in because that's what the PO said was in it. Tractor has remained in neutral. As the tractor sat for 1 year, I had changed the engine oil, spark plug to Autolite 216 and installed one of Dave Kirk's magnetic drain plugs. I intended to service the Hydro after I got her up and running. The whine worried me, thinking I might have to rebuild/ replace it.
I got the hydraulic controls freed up and working correctly. The front port handle was rotating around the lever to the control box. I cleaned the tube and arm as best I could, sprayed with starting fluid, let dry, then applied J&B around it as best I could, hopefully it'll work!
