Old 12-15-2016, 10:19 PM
jcsmith jcsmith is offline
Default Aluminum oil pan torque spec
I have an aluminum pan on my K301 and need to know the proper torque spec. The service manual only mentions steel/cast iron. I know most of you frown on the aluminum pans but this one is still in great shape.
Appreciate any answers.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 12-15-2016, 10:24 PM
Same torque.
Old 12-16-2016, 08:06 AM
The spec's in the manual are for whichever metal the bolts screw into and the size & strength/grade bolts used.
Making sure they are tight and stay tight is the important part, Especially in an aluminum pan used in a QL. I have opted to replace mine with cast iron pans.
Old 12-16-2016, 11:11 AM
Thanks fellas. That makes sense. Do either of you know when Kohler started using aluminum pans? This is on a service replacement engine in a 104.Thanks again.
Chris
