Old 05-04-2016, 11:51 PM
jeepjimmy jeepjimmy is offline
Default Napa paint?
I'm restoring my 102 and undecided what paint to use. My local NAPA carries Martin Senour paints and can mix custom also. Saw they stock gallons of premixed factory IH yellow enamel http://www.martinsenour-autopaint.co...rcial-coatings. Or, I can have them custom mix. What is your opinions?
Old 05-05-2016, 06:16 AM
Did you look here...??? Paint Chart
Old 05-05-2016, 06:37 AM
Merk Merk is offline
I use Martin Senour Cross Fire paint on my IH Cub Cadet 100 and 70. I used Cross Fire paint on My Project Uncle Dick Cub Cadet 70. 7 years ago and have a IH Cub Cadet 100 that was restored 9 years ago. The paint on both looks great.
I used the paint chart that R Bedell posted.
Project Uncle Dick
Cub Cadet 70
Old 05-05-2016, 10:18 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Napa 99-3857-L (actually 99L-3857)
99 represents Martin Senour acrylic enamel
L is the price code (L is the cheapest to mix btw)
3857 is the mixing formula (this number will change according to color)
If you use Crossfire the 99 will change to 53 but everything else stays the same. Crossfire is much better paint than its price would lead you to believe. Not all stores mix both as most of the toners are different.
I have painted 3 race cars with Crossfire and was happy with the results. If you decide to go with the more expensive Martin Senour paint it will give you noticeably better results.
As with all paint brands, don't deviate from the product data sheet recommendations and you will be fine.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 08-29-2016, 08:16 PM
got this today. will start painting later this week. http://farmallparts.com/Cub_Yellow_Enamel_Paint/p25040
