Old 06-24-2016, 07:56 PM
Rainman4820 Rainman4820 is offline
Default Seat Fenders Assembly on a 126
The fenders and seat assembly were removed from this mower when I purchased. When I installed the deck/fender it appears to block the rearward movement of the shifter, ie it won't go into 1st or 3rd. Is there supposed to be shims or something else under the fender? It appears from the markings that it was directly bolted on....thanks!
Old 06-24-2016, 07:57 PM
Looks like you might have the wrong shifter.
Old 06-24-2016, 08:18 PM
Agreed. Looks like a wide frame shifter maybe?
Old 06-25-2016, 12:19 AM
wrong shifter.....or the tranny was replaced with one from a wide frame
Old 06-25-2016, 10:16 AM
Default Fenders
Thanks for the responses. In lieu of changing the shifter I will get out the dremel and go to work. I just wanted to confirm, however, that there should not be anything (ie...rubber cushions or seals) between the fender/seat deck and frame....the reason I ask is because when I lift the rear fenders about an inch the shifter will move as designed.
Old 06-25-2016, 11:05 AM
Rmowl's Avatar
Rmowl Rmowl is offline
Nope, definitely looks to me like the wrong shifter and/or different rear out of a wide frame as others have suggested. This is the shifter off my daughters 126 in the neutral position, it doesn't have that angle at the end like yours is showing
-Rick
IH 782
IH 126
CCC 1863
Old 06-25-2016, 11:31 AM
The 126 is the 3rd rarest model cub so before you butcher it with a dremel tool I urge you to find the correct shifter, I have one and if your interested in it send me a pm.
Old 06-25-2016, 11:37 AM
X2 on DON'T SCREW IT UP!!!
Old 06-25-2016, 12:15 PM
Eye never seed ah 126,
But would a person be able to heat the lever near the trans and curve it the needed amount downward??
Seems a lot easier to me.
Old 06-25-2016, 06:44 PM
Default Shifter
PM on the way, thank you
