Old 06-19-2016, 02:01 PM
zimm17's Avatar
zimm17 zimm17 is offline
Default LED headlights?
What are some nice LED headlights? I went with 50watt GE bulbs, but they run the battery down. I don't think the generator can keep up.
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 06-19-2016, 02:16 PM
A normal headlamp rated at 50W will draw about 4.2 Amps. Running two would be 8.4 Amps. The Charging system on a Cub Cadet, if all is working as it should, will put out 15 Amps. There should be more than enough charging to handle two 50W headlamps.
Old 06-19-2016, 07:54 PM
zimm17's Avatar
Well I'm not sure, but after blowing snow the last blizzard for a few hours with the headlights on- when I shut the tractor off to clear a clog- it would barely turn over. When I turned the lights off, it held a charge just fine. I don't think LED's would hurt in any case.
1973 Cub Cadet 149
Old 06-19-2016, 08:00 PM
LED Headlamps would less amperage than the traditional incandescent type.
BTW, the normal & correct incandescent lamps that Cub Cadet used were #4411, that were 35W rated.
