Old 02-27-2016, 10:18 PM
CubyFan CubyFan is offline
Default 1440 Broken Trans Bolts - Easy Out Warning
I've been waiting too long to fix a 1440 with 4 broken Trans bolts. Runs like a top but the trans actually rocked back and forth when on the move. Pulled the trans today and wrestled it into the drill press. Drilled all four bolts. First one came out effortlessly with the easy out but the second one wouldn't budge. Torqued it so much I decided I might break the easy out in the hole (been there). I drilled it out to fit the largest possible easy out. Put a big wrench on it, still didn't budge. Torqued it so hard it the force pushed out on the edges of the hole and cracked a piece out of the trans case. The last 2 put up a struggle but came out ok. I plan to re-tap the hole and put a new bolt in. It should be ok strength wise because it is on top, has plenty of room for threads, and I have a set of the SAMMAC/Xtreme brackets ready to go on.
Definitely operator error on the easy out-don't use them much. Sam had suggested welding a nut on the broken bolt. I tried that first without success due to the flush bolt head. Thought the easy out might be the way to go. Any other thought/suggestions?
Cheers, Rick
Old 02-27-2016, 10:40 PM
Since that hole is already messed up, I suggest using a threaded insert
http://www.mcmaster.com/#standard-th...serts/=11bbq26
Take notice the drill size for the threaded hole needed is larger than a normal tap drill size.
Jeff
Old 02-27-2016, 10:50 PM
I may try a Heli-coil kit, then I can use the original size bolts.
Thanks Jeff!
Cheers, Rick
Old 02-27-2016, 10:57 PM
Thanks Jeff!
You can still use an original size bolt with the insert I posted the link to. If you get the thin wall , it's a 1/2-13NC thread you put in the buggered up casting and you still have your 3/8-16 NC standard size factory bolt.
With how that casting looks, you need all the strength you can get. I've installed thousands of heli coil inserts and I would use a Keensert stylr insert for that repair.
Your tractor, fix it how you want.
Old 02-27-2016, 11:29 PM
Ordered the insert from McM, looks much stronger. Thanks again
Cheers, Rick
Old 02-27-2016, 11:31 PM
You're welcome, glad I could help.
Old 02-28-2016, 09:23 AM
john hall's Avatar
Jeff
I'm with Jeff! Those inserts are pretty darn strong. I don't know what style you bought but some of them require using an oversized drill for the thread size on the outside of the insert--research what you ordered.
Easy outs are kind of like that line from Kenny Roger's The Gambler, "know when to hold them, know when to fold them".
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-28-2016, 11:51 AM
Ric
That should work just fine. When I have one broken off flush I weld a large washer to it and then I weld a nut to the washer. Wish I had a pic of one.
While you have it apart I suggest that you drill some oil return holes in the case.
Old 02-28-2016, 12:30 PM
V30crewcab V30crewcab is offline
Just did the same things a couple weeks ago. Got it tigged up and retapped it. Wasn't happy that happened!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-28-2016, 12:44 PM
gdheck's Avatar
gdheck gdheck is offline
+1 on Sam's approach. That has been working for me for years with an almost 100% success rate. The washer is much easier to weld to the broken bolt than reaching down inside a nut and then you just weld around the bottom outside of the nut. I like to use a fender washer, since it protects the surrounding material and allows the use of a larger nut.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
