Just got a new 1200 yesterday. It runs and looks pretty darn good except the hood fit. It seems to come up short on fit to the dash panel. I tried to move it back but ran out of slot room on the 4 mounting bolts. I tried moving the dash panel, but only limited success. Seems one side is up off the frame when the bolts are lose and the hood is hand fitted.....till the bolts are torqued.
What do you experts recommend to get the hood to fit better? It was banging and making a horrible racket, sounded like it was a sick diesel hiding under it! thanks |
Can you get any from the hinge?
Can you get us a picture? Should be plenty of adjustment to get the right gap.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
yes pics coming!
thanks! |
Once you get it fit better you can add some of this vinyl door edge to the back edge of the hood to reduce some of the rattle;
Vinyl door edge # 8451A47 http://www.mcmaster.com/#catalog/122/3857/=12ard4s Good luck! ![]() |
Fender shims under the two front bolts,let the grill lean back some
You should be able to adjust your nose piece as well to slide back a little where the nose connects to the grill base. That should do it for you.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
