Old 02-06-2016, 10:45 PM
Bob95065 Bob95065 is offline
Default Tires for 1450 - setting up for tilling
I have a 1450 that came with a #2 tiller that I want to get ready to till up a garden for my wife. The tractor has original tires that sat out in the weather for decades. They are dry-rotted and don't hold air.
I want to put a set of lug tires on the rear and tri rib tires up front. I have some questions:
For the rear tires: I am looking at a set of Deestone 23x10.5-12 tires http://www.ebay.com/itm/2-23X10-50-1...QAAMXQMTlRbHdk Will they fit under the fenders?
Should I go with 6 ply or 4 ply tires? Which would be better and why?
What size tires will fit the rims on my 1450? The original tires are 16x6.8-8. Any suggestions for tires?
Thanks,
Bob
Old 02-06-2016, 10:57 PM
the 10.50's will fit under the fender but i beleive the stock size is 8.50 so the rim width wouldnt be ideal, the front tires will be 16x6.50-8 but the only tri ribs available in that size are firestones and there $70 each. i suggest you take a look at these as a cheaper alternative http://www.millertire.com/products/i...70-60-8-6-ply/ many members have them and say there great.
Old 02-07-2016, 07:28 AM
Stock rears on a 1450 are 23 x 10.50 -12.
Old 02-07-2016, 07:33 AM
barkerwc4362 barkerwc4362 is offline
Default Vredesteins
I run the Vredesteins on the front of my 332 with Firestones on the back. You can't go wrong with the Vredesteins. They give great flotation and I have no problems turning. The 332 does however have power steering. The Vredesteins give it that "big" tractor look that I remember as a kid (long time ago) plowing with a 966 International.
Bill
Old 02-07-2016, 07:37 AM
mickb72 mickb72 is offline
Default cub
Deestone tires are under sized compared to other brands. a 10.50 tire is slightly bigger than a 8.50 of another brand. Check around on the web, there's a lot of people that have said this. Mike
Old 02-07-2016, 08:40 AM
front of my 332
What is a 332....????
Old 02-07-2016, 08:44 AM
When you say that they are undersized do you you mean the width or diameter?
Thanks for all the suggestions. Are there any other alternatives I should look at?
Old 02-07-2016, 08:57 AM
Cant beat the Deestones on price, $130 a pair at my local tire store. They are a little shorter than others.
Old 02-07-2016, 09:14 AM
JD332 is a Diesel GT
Old 02-07-2016, 09:33 AM
Am I better off with 4 ply or 6 ply tires?
