I've been lurking for a few days, just looking at all the valuable info on this site. This is my first post.......I bought a model 1872 Cub Cadet the other day. It ran/drove when I looked at it, and I figured it was worth the $300 asking price, so I snagged it up. So far I've changed the engine oil,hydrostat oil, greased everything with a grease zerk. I had to put a tube in the right front tire and replace the oil sender. I think I after I sharpen the blades I will be able to mow with it. I was told it came with a front blade also(He has to dig it out of his garage) I bought it to help out around my property with mowing/landscaping/etc. I still have to figure out why the PTO isn't kicking on when I hit the switch....that will be tomorrow's project. I have a few questions I haven't been able to find an answer for on the forum.
1. It doesn't have a 3 point, did any of the 1872s come with one? 2. Would it be possible to add one? or do I have to go the electric linear actuator route? 3. What all parts make up a sleeve hitch and where could I find one? 4. What are the weak points on this machine, stuff to look out for, besides the rear axle? 5. Any recommended upgrades or mods to this machine to help with usability/performance? |
Denny Original Member # 389 Saw It Wanted It Had A Fit Got It ![]() ![]() ![]() MY Cubs Original x 2 , 70 x 7 , 71 x 2 , 72 x 4 , 73 , 76 , 100 x 3 , 104 , 106 , 109 , 128 , 129, 147 x 2 , 804 , 2 Wheel Horses and Lorenzo's 2 - 804's |
novaman_68 , you got a GREAT DEAL!
I bought an 1872 a few weeks ago, and I have not found any weak points yet. It mows fantastic and is very powerful. I bought a 3 point hitch from http://www.xtrememotorworks.com/ They make quality products. ![]() As far as the pto not kicking in...it could be a few things. Check your wiring to make sure all the connections are tight. There is a safety switch under the seat that could be bad. The switch on the dash may need replaced. The gap setting on the pto may need adjusted, or maybe its a bad pto. Good luck with your new Cub!! |
Novaman: Welcome to the OCC... The most commonly replaced part in the PTO circuit is the PTO Switch! I bet Roland has posted the wiring diagram for it in the tech section...Do your wire tracing like CBH said and you will find the problem. The Service manual covers the PTO ...I recommend you get one!
Myron B
Myron B East Texas Most of of the fleet: Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with. |
Kubota B7100 HST 4x4 w/FEL, 4' Bush Hog, Woods RM400 Finish Mower Original Member #54 |
Yeah no kidding! $300.
Now get you some side panels. BTW no sleeve hitch and no electric actuator anything....others have told you right, get you a cat0 for it and with your luck you'll find one of those cheap too. Also that blade, if it is and it likely is a Haban it's worth $400 to $550 sooooooo....make sure that man digs it out of his garage. Scott |
Here is a Typical PTO electrical circuit and is correct for the 1782...
![]() Your Tractor may or may not have a Rear PTO. If you don't ignore the "directional switch".
Thanks for all the replies
Toyman----Yes it has the 18hp magnum still, dual hydraulics, a 50" deck, and I don't know if the front blade is power angle....I haven't got it yet. Murphycc----I didn't realize I was missing side panels until you said something, are the panels unique to an 1872? What other models might work? R Bedell---Thanks for the wiring diagram, I am going to look at the PTO this afternoon and see if I can figure it out. Also, about the rear PTO.....is it above the rearend, way up under the seat? I see a splined shaft about 5/8-3/4" up there, but it looks way up in there for a PTO. I know the older Cubs had the PTO shaft coming out of the rear end cover. |
All the tin on the '82's are the same except for the tunnel cover (Super is longer than GT). Yeah you want them.
The splined output shaft you see is where the rear pto is driven from, you don't have a pto. Scott |
