hello im having issues with my cub 100 .it doesnt want to shift in reverse.i have to manipulate it to work but it doesnt want to stay in reverse..any hot tips from the pro's
Just guessing, broke spring over the poppet ball maybe. Do all the other gears shift and stay in proper?
thanks for responding .2 gear does not engage at all ..also there is a scraping noise comming from the gear box when in neuteral.i use to plow with it a few years back mostly useing 2 gear i think i toasted it becuase that was the only gear that made a clunking noise or scraping noise ..last week i tried to load it up a ramp in reverse after un succeeding thats when the scraping started when not in gear alsoits tough to get out of 1st to put it in reverse and reverse doesn't want to stay engaged .. thanks
as for the clutch it seem s to be working .when engegeing the pedal the drive shaft stops moving ichecked rear fluid its up to par
make sure your driveshaft stops turning when you clutch it . The 1-R shift forks like to break to.
yes the shaft stops turning when u clutch it
It could be a loose or broken shift fork or as mentioned above the poppet ball spring could be broken.
Pull the shifter and cover off and see what's going on in there.
so to pop the cover off i have to release the rearend out of the tractor thats what it looks like to me ???
![]() Quote:
http://www.cubcadetcollectors.com/ma...=988&g2_page=2 |
thanks for your help and link to manual
