Old 01-18-2016, 12:21 PM
john hall's Avatar
Default 44c on a 129
How much of a headache would it be to put a 44C deck from an 1810 under a 129? I would have both mule drives to work with.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-18-2016, 12:33 PM
I have done it, only on a 1450 (basically the same thing). You will need to change the Center Drive Pulley on the mower deck, being CCIH-59703-C2.
Old 01-18-2016, 12:34 PM
The pulleys on the 1810 mule drive are about 2" further forward than on the correct one for the 129, the deck will also be setup for a 5/8 belt and the 129 uses a 1/2 belt. If you could find the proper pulley for the deck it should work.
Old 01-18-2016, 01:19 PM
mortten mortten is offline
Change the pulley and move the left front hanger (IIRC) to the other hole. Use the 129 mile drive.
Old 01-18-2016, 02:37 PM
john hall's Avatar
Thanks guys! I'm trying to justify buying a parts 1810.
2072 w/60" Haban
