Old 12-10-2015, 01:46 PM
Conner299's Avatar
Conner299 Conner299 is offline
Default Got the 104 running!
You guys may remember my intro post, and how I recently acquired my first Cub, a 104. I found her on CL, and she looked to be a good deal. Truth be told, she still is. She needed a little work, though. The ad said running, but when I went to look at her, that wasn't the case. I was able to talk the owner down from his original price. I don't think I overpaid, by any means, but it wasn't the steal I sometimes hear about. I figured she had a stuck valve. I could feel negative pressure, at the spark plug hole, but no positive pressure. After getting it home, and tearing into her a little bit, I was pleased to find it wasn't a valve... Just a head gasket. The pic of the head shows a whole piece missing between two of the bolt holes. I took the head to work, media blasted it, and did the sand paper and glass deal on the gasket mounting surface. I then proceeded to rebuild the carb, and get fresh points, condenser, and a new plug. The spark plug the PO had in it had twice as much thread as it should've. I adjusted the valves, and points, and the voltage regulator as bet as I could. Mainly just the air gaps on the regulator. Along with some elbow grease and simple green, she's coming along nicely. The deck spindles will probably need a rebuild, but overall the deck is in good shape. I also scrapped the deck belly and sharpened the blades. My only problem, that I think I have narrowed down is a nice clacking while its running. My guess is the teaser spring. If not, it needs replaced anyway, so I'll service the whole clutch while I'm in there. I have some pics to resize, and a YouTube video to link, so I'll out those in my next post.
Old 12-10-2015, 02:01 PM
Conner299's Avatar
Pics of the teaser spring, valves before and after adjustment, and pic of the head gasket... Still waiting for my YouTube video...
Old 12-10-2015, 02:35 PM
Man Connor I guess you did have a blown head gasket wow that may be the worst one I've seen yet. Glad to hear of another one back on the road if you will. More pics please
Old 12-10-2015, 02:57 PM
Conner299's Avatar
Here's the video, of getting her running. Any thoughts on the clacking are welcome, if you guys don't think its the teaser spring.
https://www.youtube.com/watch?v=zt9v01UAc2k
Old 12-10-2015, 05:04 PM
Conner299's Avatar
Yeah... I thought I had lost the chunk when I took the head off. Looked everywhere for it, just in case.
Old 12-10-2015, 09:19 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Funny how the video is 1 minute 4 seconds long, 1:04
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 12-10-2015, 11:52 PM
My 104 was noisy even though the PO had bored/new piston/rod etc, lately I removed the clutch for a rebuild and cranked it up and it is silent. Clutch pilot bushing and throwout bearing all wiped out, I guess 46 yrs is about the limit....
Old 12-11-2015, 12:08 AM
Congrats on getting it going sounds to me (like I can hear good) like possibly some PTO rattle...
Old 12-11-2015, 12:28 AM
Conner299's Avatar
I don't think its the PTO. No change in the sound when it is engaged/disengaged... Both with/without the deck... I even checked by hand, and it doesn't feel loose, at all. If you look real close at the teaser spring, there is some telling wear. The main two spots being right at the spring break, on the motor side... And right above that, on the clutch spring side of the break, where it looks concave. I think the spring half on the clutch spring side is coming around, and then slaming forward after it gets past the break. That's the only thing I can think of...
That's awesome, regarding the video length! I hadn't even noticed it!
Old 12-11-2015, 12:29 PM
Congrats on getting your 104 going! Thanks for the vid.
