Old 04-19-2010, 10:17 PM
dkw45 dkw45 is offline
Default Should I buy an older Cub?
New here, looking for some input. My garden keeps expanding(two 75x100 beds right now and more to come if can work it with a machine). I'm wanting to start working it with a garden tractor. I would also like to be able to use a back blade or box blade for some minor leveling work.
I have a Cub Cadet LT1050. I know I can buy an electric sleeve hitch for it. I also believe I can adapt an MTD manual hitch to fit it. Worst case scenario, I can build one from scratch. My main uses would be; bottom plow, disk, cultivator and blade.
Would my Cub be sufficient for this work or would I be better off to buy a true Cub garden tractor? I would like to be able to use the same machine for mowing and gardening.
Thanks for any advice
Old 04-19-2010, 10:26 PM
Welcome to the forum! You would be much better off buying a garden tractor. An LT1050 is not designed for any of those implements.
Old 04-19-2010, 10:27 PM
murphycc
Guest
Posts: n/a
No your LT is not sufficient. Yep take a look around, I'm partial to the "82"s.
Scott
Old 04-19-2010, 11:01 PM
johncub7172's Avatar
+1 I dont think the Lawn Tractor 1050 should be doing anything but cutting lawn.Yes! Get a true International Harvester Cub Cadet Garden Tractor. Enjoy the journey and Welcome to this site!
Old 04-20-2010, 01:41 AM
gravest's Avatar
gravest gravest is offline
The LT is exactly as it states (lawn tractor). It just isn't built for the work you are asking it to do. An older IH cub cadet would definitely do the job. You'd be much happier and it would last a lot longer. Mine is over 40 years old.
If one cub cadet is good, Two or more would be heaven.
Old 04-20-2010, 02:11 AM
ajgross ajgross is offline
Inactive Member
Plus, you can probably find a decent old one for the cost of a electric sleeve hitch for a new tractor.
AJ
Old 04-20-2010, 08:25 PM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
Buy an older cub. I just got a Cub 1650 hydro and I love it. It has plenty of power to pull those types of implements. And its hydraulic lift!
Old 04-20-2010, 10:06 PM
Thanks for the input, guys. You all told me pretty much what I expected to hear. I have begun my search for a real Cub. Wish me luck.
Old 04-21-2010, 03:22 AM
Plus, a refurbished IH Cub Cadet will last 40 years doing hard labor... An LT1050 will be worn out in another 5 years just cutting grass.
Old 04-21-2010, 08:56 AM
toyman's Avatar
toyman toyman is offline
Also, with patience you should be able to find a good tractor and attachments for a bit less than a new LT. It will last longer, be easier to work on, and give you a lot more enjoyment.
Original Member #54
