Old 05-16-2015, 10:24 AM
imnotacollector imnotacollector is offline
Default Cub cadet 129 PTO question!
I called a guy on a 129, which he says the only problem he is aware of is, the pto will not disengage. My question is, would the button in the pto be the cause of it, and how hard of a repair could it be? Thanks
Old 05-16-2015, 10:28 AM
It could be, but rebuilding the entire PTO is not that big of a deal.
Old 05-16-2015, 10:31 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
its hard to say, could be an adjustment. could be buttons, if the buttons are gone you could need a lever and fingers on the pto, could be a seized bearing behind the pto, repair could be simple could be difficult if you need to take the pto off. you'll have to look at it and be the judge
Old 05-16-2015, 10:32 AM
Ok, thanks for the reply. I just wanted to have an idea of what I would be getting into it I brought it home. Which a deck and front blade he is asking 350 obo so I figure it's worth looking at. Thanks again.
Old 06-27-2015, 01:52 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Nope, the problem is that the engine is running.
Shut the engine off and the pto quits spinning.
Cant get that with satellite
Old 06-27-2015, 01:12 PM
If the pto is one with the safety disk, which I believe came out in 1974 and it is missing one of the disk, then it could be difficult to find parts for. I have had more 129's than any other cub cadet in my collection. Some have had older style pto's on them and some have had the safety disk pto's on them. So, your repair may be simple and cheap or it could be a bit more involved and a bit more expensive! Pictures would help...
Old 06-28-2015, 05:16 PM
Some guy on epay sells the brake disk for the brake style pto's (just the brake material, not the steel disk that it is bonded to.
And yes, Cub Cadet 123 is exactly right, if parts are missing, it will be little more expensive and a little more involved.
If the engine runs well and doesn't smoke, I believe it is well worth the money.
Old 06-28-2015, 06:20 PM
TIMCRUTCHER TIMCRUTCHER is offline
My 71 PTO quits spinning every time I shut the engine off. I thought that was normal.
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 06-29-2015, 01:01 AM
Rescue11's Avatar
That be the point... Greg!
