Old 08-28-2015, 12:18 PM
zimm17's Avatar
zimm17 zimm17 is offline
Default What primer for iron guard paint that's not from case/IH?
I'm about to shoot the sheet metal for my tractor. I have case/IH ironguard paint, hardener, and thinner, which have worked great through my HVLP gun. So far I've only used Rustoleum primer and the paint was worked fine so far. The fender pan and hood are a little too big to prime with a rattle can. Is there a primer I can use that's compatible without having to drive 3 hours round trip to the nearest Case/IH dealer?
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 08-28-2015, 12:33 PM
I use ppg primer under the case/ih paint all the time with no issue. Just about any 2 component primer will be fine since its fully cured before it top coated, most incompatibility issues come from wet on wet application.
Old 08-28-2015, 12:34 PM
zimm17's Avatar
Tim,
What's a 2 part primer? Thinner and primer? Any certain type of PPG primer?
1973 Cub Cadet 149
Old 08-28-2015, 12:47 PM
Originally Posted by zimm17 View Post
Tim,
2 part will be a primer with a hardener/activator. ppg's shopline brand has a cheap primer that works pretty good, its # is jp285
