Old 06-06-2015, 10:32 PM
damage41 damage41 is offline
Default Hydraulic lift in 122
I picked up a 122 today with hydraulic lift,sleeve hitch and hydrostat transmission.one of my questions is did someone switch hoods or was hydro transmission an option?The previous owner said that the seal was bad on the hydraulic pump upon closer inspection I can see that the shaft has some side to side movement are parts available for these pumps?
Old 06-06-2015, 10:35 PM
Welcome to OCC
Sounds like you have a 123 with a 122 hood.
Your grill look like this one?
Old 06-06-2015, 10:38 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Hydro 122 would be a 123, probably wrong hood. Which pump is leaking? The lift pump or trans pump?
Edit- You beat me Jeff!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-06-2015, 10:59 PM
The lift pump. Ya Its the same. I will try and post pics of my 1650 project later.
Old 06-07-2015, 12:43 AM
Yes, parts are available, but for the main parts of the pump they are pricey. Cub Cadet wants nearly $400 for the shaft..... but it's available. If you know of a hydraulic supplier, they may be able to get it cheaper. It's just a Sundstrand hydro unit. It's not CC specific. Your best bet is to just buy another unit. You can get a used one for around $75-$150 depending on where you look.
EDIT: Here you go:
http://www.ebay.com/itm/CUB-CADET-10...item35eb27161e
