Has anyone on here installed an electric lift on a Cub 100? I have all the components from a Cub 147, except the switch and frame bracket. I would need a photo and dimensions of the bracket from someone who has one mounted on a narrow frame other than a 147. I have seen a photo of a 127 and the bracket looks like a flat piece of steel bolted to the frame.
The electric lift and brackets were the same for all the narrow frame tractors. Doesn't matter if it's on a 127 or a 147. Same.
Sell the lift to someone who needs it for a 147. It isn't worth the time to mount. They are slow. |
![]() Quote:
I slow too. I have a 147 with electric and am happy with it. |
![]() Quote:
http://www.cubcadet.com/equipment/AR...0-A/0019900008 |
![]() Quote:
I didn't realize they were welded to a 147.
Oh well. I still don't see why you need to make one exactly like what was used. Nothing to a bracket. Just make one that works. The 100 didn't come out with e-lift, so what does it matter if the bracket is exactly like the one that would have came on an e-lift. But I digress. Maybe someone will get you the dem's and you can make it. |
![]() Quote:
How about a cup holder?
How bout a hydraulic cylinder?
