Old 06-06-2015, 07:37 PM
coinman66 coinman66 is offline
Default Can I use a 5 prong ignition switch on a Cub 123?
The 5 prong switch is marked with letters on back. B G L S M. I have to hook up my orange safety switch wire, my green ground going to solenoid and my black wire that goes to coil. Just don't know where wires go on what prongs? Any help guys would be appreciated!
THANKS!
Old 06-06-2015, 07:41 PM
And also this is how I've got my voltage regulator hooked up. Hope it's right? I don't think it's the original one though? The gray middle wire is hooked to an BAT prong, the top yellow wire is hooked to an L prong and the blue wire is hooked to an unmarked prong on back of regulator? And Pink wire is ground.
Old 06-06-2015, 07:48 PM
I would use the correct one, especially if you have a new voltage regulator. That one is for a magneto ignition.
Up to 530 and counting...
Old 06-06-2015, 08:06 PM
Ok, that's what I will do. Order one tomorrow.
Old 06-06-2015, 08:42 PM
The yellow wire should be on the f terminal not the l terminal
Old 06-06-2015, 11:03 PM
I was wrong, yellow wire IS hooked to top F terminal. So should the blue wire hooked to unmarked terminal in back be hooked to bottom L terminal?
Old 06-06-2015, 11:36 PM
http://www.onlycubcadets.net/forum/showthread.php?t=35
Old 06-06-2015, 11:42 PM
JMECH thanks but I have this info. My problem is, I don't think it's the original VR for my 123. This particular VR has a F Bat and L terminal, with an unmarked terminal on back of VR?
Old 06-07-2015, 12:05 AM
The one on back is the G terminal.
Old 06-07-2015, 09:37 AM
Ok thanks. So I guess u can't use a 5 prong ignition switch at all?
