A few months back I inquired about using a "standard" drive pulley on the crankshaft for the starter/generator. With that being said after taking measurements of the original pulley with the clutch basket on it (that i don't need anymore) it seems the pulley does not have a very wide groove for the belt to ride. My original measures 7.5" o.d. with a .375" v-groove opening to fit on a 1.0" shaft. Can anyone direct me to a similar in size drive pulley to purchase that does not have the clutch mechanism?
Midwest Super Cub sells them
http://www.mcssl.com/store/midwestsu...r-engine-parts If that's too much $$, then try McMaster Carr. |
One off an original will work.
try our sponsors or put an ad in the wanted section.
Got mine from Grainger for like $20 including shipping.
I went to Grainger.
They give you a choice of two..............(one piece units: cast iron). One for $57.20 or one for $51.90 but wait! today it is on clearance for only $5.75 Yes $5.75 http://www.grainger.com/product/GRAINGER-APPROVED-V-Belt-Pulley-4RYT2?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/3X829_AS01?$smthumb$http://www.grainger.com/product/GRAI...AS01?$smthumb$ |
Thanks to all for the info. Looks like the $5.75 one from grainger is the deal of the day. I just need to e-mail them to find out the max RPM of it. I need it to handle a max of 4000.
Got mine on clearance also, but not as good as you!
![]() Quote:
$40 and up elsewhere. |
The engine in these runs at 3600 RPM. I set all mine to run at 3800. I wouldn't suggest that pulley as it's RPM range is too low.
![]() Quote:
Although MSC does not show rpm ratings for them. Hey Ford4150, Might want to check that pulley on yours.................... |
