Old 04-03-2015, 11:05 PM
machinehead323 machinehead323 is offline
Default 50A deck spindle questions
I have a 50a deck on my 1650 that i run pretty hard. i relegate it to the rough mowing of my 2 acres. It regularly chomps up dead branch parts and even the occasional mesquite tree. it has the hardened IH blades on it and the water pump bearings. i had one that was making a little noise so i threw in some more grease and it didn't quiet down. i wouldn't say that it is too bad sounding but the other 2 don't make any noise at all. when i grab the blade and wiggle i can see the spindle shaft moving in the bearing holding housing. the bearings themselves seem tight. so I'm not for sure yet if my bearing holders are getting a little loose from all the violence or if thats just how they are. i see there is an upgraded replacement unit that can be rebuilt but they are pricey. i have also heard something about the 2000 series may work but there is something with a spacer to deal with. are there any other options for upgrade out there. its just getting mowing season and i dont want to be stuck without. I'm also looking to put in the speed pulley too
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 04-04-2015, 07:48 AM
Without any pictures, it is hard to say.
But it sounds like you need the ST745 bearing.
I found it available at: ST745
Old 04-04-2015, 08:12 AM
Sounds like the bearing is wallowing in it's stamped housing.
Don't think a new bearing will fix that.
I have eliminated those old style bearings and replaced them with the newer
taper Timken style bearing assy's much,much cheaper to replace, ( Lm 11949 and Lm 11910) (outer wheel bearings on older GM vehicles) but you have to change to the Aluminum housings also.
I was lucky as I had a junk deck from a 1720 and just used those assemblies.
I didn't need any adaptors/spacers.
As far as using that deck for a "brush hog" they are aged and thin now-a-days and the spindles tend to bend the housing mounting area causing the "cut" to not be as nice/even as it was new, I'm sure. BTDT.
Old 04-05-2015, 10:26 AM
I for sure want to upgrade to the new bearings. Seems like it would hold up better for what I do withr the deck. So what all model of deck should I be looking for. Anyone have a lead on a set of used bearings
Old 04-05-2015, 10:28 AM
Old 04-05-2015, 01:49 PM
I see a lot of the newer models still used the 50/38/44 C decks. I'm trying to expand what I'm searching for when searching Craig's list and eBay for used decks to strip the spindles from
Tags
1650, 50a, spindle
