Old 03-05-2015, 09:29 AM
JLM78 JLM78 is offline
Default Do you use Hytrans in a super 1572 Cub Cadet?
I have a 1572. It has like foam / air bubbles in the rear end, and don't want to move.
Old 03-05-2015, 10:18 AM
Let the air bubble clear. Is it full?
Old 03-05-2015, 12:43 PM
Do you have a clean Hydro Filter on it....???
Old 03-05-2015, 01:26 PM
Maybe add some Beano, it is suppose to eliminate those
embarrassing "air bubbles" in the rear end.
Sorry, with all this awful weather, I just had to say it.
Old 03-05-2015, 02:17 PM
When the weather gets better that's first thing change the filter. I just Would like to make sure the pump is good. Before I take it out And put back in
Old 03-05-2015, 02:33 PM
Saying that you want to make sure a pump is good before changing the oil and filter is like saying that you want to know a vacuum is good before changing the bag. If the filter is plugged..... the pump is basically no good. But with a new filter it may be fine. So....... crap out the money and change the filter.
On another note, air bubbles is caused by cavitation (air leak on the suction side) which could be caused by a bad seal on the charge pump, or.... a plugged filter.
