My 1650 was gone over about 5 or 6 years ago before I bought it and not used
much till last summer, it just looked to good to get worked. I never open removed the tunnel cover till last night. My fan looks like a hockey players smile. Only one good tooth and a bunch of nubs. Well I have it all set up for snow removal and we get the better part of the last storm almost 17" and lots of 3' drifts. I plowed for about 45 min. and thought it should get a rest, not because of anything mechanical. Just couldn't stop thinking about the fan and overheating my cub. Well I let it sit and had a cup of joe. About an hour rest and finished the other half of the plow job 45 min or so. By the way that was my first big snow with the 1650 WHAT A MACHINE!!!!!!!! It didn't struggle at all. My question for those with the knows is. In the winter does that fan do much??? How hard is the job to replace it?? (I Don't wanna tie up the tractor 3" more tonight and more tomorrow) and my 102 is in complete tear down.
1978 / 1650 Dual stick, 50a Deck, 42 Blade 1966/ 102, 44 Deck, 42 Blade 1951/ IH Refrigerator, turned kegerator 3 more IH cubs in the works Many MTD Lt's and 1 Huskee Gt |
Just my 2 cents but I don't think the messed up fan will be a problem during winter but you should find out if you have a drive shaft problem and replace the fan for summer and mowing duty.
When you say driveshaft problem you mean loose and woobly I guess. I did grab it tried to move it and couldn't.Thinking back I should have asked myself why did it break in the first place, I haven't looked at it while running. I will do that tonight before plowing. Kind of different I wonder why a log spliter doesn't have a fan
I agree!.....................
![]() Quote:
They break because you can get new ones...
most time they break because it is 40 years old and they are brittle.
Come on Sam isn't you're crystal ball working haha Just thought there might be something common breaking the fan besides old age. Beleive me I appreciate your and all other replys and opinions
On mine the fan comes close to the lift linkage, while the cover is off, move the lift,up/down and see if something could be hitting the fan.
Like others said you are not going to do any harm in cold weather. Just to put your mind @ rest, feel your rear end after working it hard, you will be lucky if it is just warm. Well, I better clarify, the tractors rear cover plate I mean ![]() |
I went out and checked the drive shaft it seems like it is solid and running true rag couplings aren't worn. Now that I examine it closer this didn't happen recently the breaks are old. That lift linkage is close might have hit it can't tell without a new blade. By the way after almost an hour of pushing of hard packed snow,you know the stuff that the county plow trucks leave at the side of a main road. I have 40' of that to keep open,the rear end was just warm. I'm not going to woory about it till spring. Gotta get my 102 project done.
