Old 03-31-2010, 08:46 PM
jayf107188 jayf107188 is offline
Unhappy 1650 k341 crankshaft
Just had my crank reground it had .002 to .004 in.
ware on it .It came back at 1.488 in
should it have been 1.490 ?
will it work ok with a 010. under sized connecting rod ?
Old 03-31-2010, 10:14 PM
I think your machine shop owes you a crankshaft. A properly-machined 0.010"-under crank should be 1.4900"-1.4895". They ground it under the max wear limit for a 10-under throw, which is 1.489".
Since it's at a smaller diameter than the max wear limit, it'll knock and probably not last long. Take it back to the machine shop and have them set things right.
