Old 11-13-2014, 12:15 PM
carhopper's Avatar
carhopper carhopper is offline
Default Mower Deck Roller Problem
Guys, I have a 3206 which I absolutely love everything except the mower deck. The rear rollers assembly has broken off twice and this last time it went under the mower deck and got chewed up. Now I need all new blades and the entire assembly which is pricey.
I live on very rough terrain so it gets beat up with rocks and pits. The front casters do just fine. I am wondering if anybody has retrofitted the rear with casters just to provide support. I think it would work so much better.
2002 3206 Locking Differential
Old 11-13-2014, 04:23 PM
Do you have a rear center roller??
That seems to help this deck,,,,,,,,,,,,,,
Old 11-13-2014, 11:05 PM
Oak Oak is online now
WOW! What are you mowing? That assembly uses 4 bolts to hold it onto the deck shell. Did you pull the complete assembly up under it and chew it up? I think that is one of the better decks with the large rollers on the back. This is mine that I replaced all the crappy OEM rollers with new rollers with sealed bearings. The shaft that the rollers go on is just a piece of 3/4 rod IIRC and can be replaced for about $30.
The later 3K machines did away with the rollers and went back to the anti-scalp wheels but those machines have a deck height adjustment stop on the floor of the tractor. I'm not sure if yours has that. I know that when you back up with the deck lowered the rollers can sometimes catch on things but I wouldn't think it would pull it off. Do you have any pictures of what it looks like now? There is a guy selling the newer type deck that is NOS in Tennessee on Ebay now but I don't know if that will fit your machine.
Old 11-17-2014, 09:37 PM
carhopper's Avatar
Sorry guys I thought I subscribed to this one. Yes that's my deck. When I smack into a rock or hill it eventually breaks one of the two lower sliding bolts, then it's only a matter of time before it swings out, bends the upper flange, and is under the rear wheel. I guess I'll just rebuild it again.
Old 11-18-2014, 07:09 AM
You may want to be a little easier on it.
